I am getting a slight gap even when using Nero to record a mix.
By the way I am using a Numark Total Control that is for sale at the moment.
I never got the gap when I recorded with the Behringer bcd2000.
Thanks in advance
Thanks in advance
Posted Sun 12 Aug 07 @ 9:34 pm
lack1
hi mate, been a while since i used nero but i'm sure there is a setting in which you will find would correct that slight gap...
Tayla
Tayla
Posted Mon 13 Aug 07 @ 2:02 pm
If you have your master track (before you place insertion points) right click the file in the Nero Burning ROM browser - select remove silence/pause between tracks. If you have alread placed track points, you will need to do this for each track.
Hope this is what you were looking for.
Ronny582
Ronny582
Posted Mon 13 Aug 07 @ 4:09 pm
hi there
just in case you dont know, mp3s have a slight silence in the beginning and in the end of a track, so if you record your mix in wav format hopefully you wont have any problems with silence between tracks.
Posted Mon 13 Aug 07 @ 6:15 pm
