SUM TIMES WHEN RECORDING MY MIXES ,THE FINAL PRODUCT DOES NOT SOUND GOOD.THE VOLUME OF THE TRACKS CHANGES FROM THE 1 TRACK TO THE LAST , I HAVE CHOSEN THE AUTO GAIN MENU ,AND ENABLED AUTO MENU ,BUT NOTHING HELPED.THIS IS A BIG PROBLEM COS MY MIXES ARE SMOOTHLESS.PLS HELP
Posted Sat 11 Aug 07 @ 8:31 pm
plz dont use all caps its considered rude
what is your system spec?
Posted Sat 11 Aug 07 @ 8:48 pm
WAT IS SYSTEM SPE.I USE WINDOWS XP
Posted Sat 11 Aug 07 @ 8:51 pm
system specification ie ram , processor ect
please dissable those scary caps
Posted Sat 11 Aug 07 @ 9:01 pm
sorry about the caps .ram 256 mb
pentuim 4
pentuim 4
Posted Sat 11 Aug 07 @ 9:10 pm
Which version do you use?
Posted Sat 11 Aug 07 @ 9:24 pm
thats quite a small bit of ram i aslo recommend you try out the newer product
www.virtualdj.com
www.virtualdj.com
Posted Sat 11 Aug 07 @ 9:28 pm
wat has ram got to do with my tracks volume.i've tried the demo version once or twice and the tracks are volume smooth,right now i;m using version 2.1v .might it be my the bit rate of my tacks /mp3;'s //
Posted Sun 12 Aug 07 @ 5:08 pm
heya try the latest demo 4.2
http://www.virtualdj.com/download.html
Posted Sun 12 Aug 07 @ 5:29 pm
i am not using virtual dj ,but atomix
Posted Sun 12 Aug 07 @ 7:12 pm
atomixMP3 is out dated -- VirtualDJ is the latest -- download the trial for ver. 4.2 http://www.virtualdj.com/download.html
Posted Sun 12 Aug 07 @ 7:56 pm
what do u mean a problem with all virtual dj .especialy when coming to short cuts .well the problem is that i dont use the cross_fader to fade but instead i use the up faders .which i can use with the short cut menu.but with virtaul dj ther is no short cuts for deck volumes or up faders .which is problematic ,coz i dont prefare the cross-fader
Posted Mon 13 Aug 07 @ 4:32 pm
what do u mean ,I have a problem with all virtual dj .especialy when coming to short cuts .well the problem is that i dont use the cross_fader to fade but instead i use the up faders .which i can use with the short cut menu.but with virtaul dj ther is no short cuts for deck volumes or up faders .which is problematic ,coz i dont prefare the cross-fader
Posted Mon 13 Aug 07 @ 4:34 pm
