Forum: Old versions
Topic: Problems with SP2???
Hi Folks,
I would like to know if there's a reason for not using the SP2 of XP. Are there any known conflicts, or is it adviceable to upgrade?
Thanks for your support,
a happy User ;))
Posted Tue 12 Oct 04 @ 12:55 pm
i got no problem with sp2
no problem either over here...
SP2 and no problems :)
Thanks - I'll update then!
Mark
If you're using a Maya USB44 soundcard be sure to get the latest driver which is 2.53, in the last verison 2.50 is has compatability problems with SP2
Reggie
