Is it better to get one with the software or with out? What are the better brands?
Thanks
Thanks
Posted Thu 09 Aug 07 @ 8:24 pm
Which software do you mean?
I recommend Segate or Western Digital, 500Gb.
Posted Thu 09 Aug 07 @ 8:31 pm
The software that comes with some external hard drives. I understand that some external drives come with software and the others don't.
Thanks
Thanks
Posted Thu 09 Aug 07 @ 8:36 pm
Make your own, try this. It has it's own power supply, so no adapter. It also has a fan. Just get a blank hard drive. If you get a ready made one, the software is probably on a disc, and is most likely a backup program. I wouldn't worry about it, because you should be able to delete it if you want to. There are other enclosures on that site, also. Also get the largest drive you can.
Posted Thu 09 Aug 07 @ 9:06 pm
