Forum: Old versions
Topic: sound problems
i have sound problem with mk2 console... just a regular set up.. laptop with mk2 console outputs directly into my amp speakers....these are new 550 watts and i seem to not get sound.. all my volumes and gains are almost at max and worked a small room and couldn't get enough volume.. anybody got info on this
Posted Wed 08 Aug 07 @ 11:53 pm
try turning up the outputs on the console software
The console software is in the system tray. It seems to go back down low on my PC each time I quite VDJ
thanks guys i have a bigger problem....
i had a virus on pc..got rid of it but had to restore my computer....my install cd for virtual mk2 was in my e drive while the restore was done.... now my virtual dj and mk2 work but i do not have acces to the mk2 controler..no icon on tray and when i go via program files i click on the icon and i get an :error loading mgs files...... so i tried to reinstall but the cd is stuck on uninstall and when i click to uninstall i get a windows exe.set eror... i think due to restore there was a problem in the drivers instalation...wondering if i can not download something to fix this
try to acess it via control pannel
if that fails do a full uninstall
and then check the registry
go to run , and type Reg Edit
and on this screen search for hercules
and delete any remaining references then reinstall
