Forum: Old versions
Topic: HELP ME!!
HI I NEED HELP! IF I BUY VIRTUAL DJ (NOT PRO AND NOT HOME EDITION) I MEAN THE NEW VIRTUAL DJ. WILL I BE ABLE TO USE THE SKINS LIKE TITANIUM MAX ON IT??? U KNOW WHERE IT SAYS LEVEL REQUIRED. IF IT SAYS PRO EDITION REQUIRED WILL IT WORK ON THE NEW VIRTUAL DJ OR NOT???/ PLEASE REPLY SOON! I NEED TO KNOW ASAP!
PS: WHICH IS BETTER? THE NEW ONE OR VIRTUAL DJ PRO? MUST NO IN THE NEXT 7 DAYS!
THANKS!!
Posted Wed 08 Aug 07 @ 5:46 pm
If you buy pro now you will be able to upgrade to the new version when it comes out.
its the same just an update :)
can you help me to. I having a problem when i load a song it takes just as long as the song playing to load. And the green computer status bar is high. what do i do?
that tell me u have a weaker system..what the spec?
