Forum: Old versions
Topic: Cueing with Numark TC + M audio connectiv
Hello Guys
Iam trying to use the M audio connectiv as a sound card, and even tought I already selected ASIO in the sound card drop down menu, when I connect the headphones to the card all I hear is the master .
Am I supouse to connect my headphones to the 3/4 outputs via a RCA connector?????
I though all I have to do is connect it to the headphones outputs.
Also I tried to use the Numark TC with my regular VDJ pro and it doesn't reconixe it.
It only works with the CUE le version that came with the Controller what do I do?
Posted Wed 08 Aug 07 @ 2:57 am
are you using the latest version , the total control is fully supported in 4.3
the conectiv im not such a fan of personly its not that well made
try these settings
inputs : none
ouputs : headphones
card : 4.1
Driver : conective
channels 1/2 main 3/4 headphones
