I just got a Behringer BCD3000 yesterday...
Anybody know what to do to setup the audio correctly? It works in traktor because it's natively supported, but how do I set it up manually in VDJ?
Is there something I must do in audio MIDI setup? What do I select on the VDJ config screen? Right now, both outputs are working, but I can't use both decks, and the crossfader doesn't work.
Anyone out there with one that can help?
Also, (to the VDJ team) do we have a timeframe as to when this will be officially supported, so the lights work? Do you know when exactly VDJ will be updated?
Thanks,
DJ RPG
Thanks,
DJ RPG
Posted Tue 07 Aug 07 @ 9:06 pm
like with all consoles not natively included you need to midi map them
midi mapping
now it should control vdj
as to the soundconfig
on the console soft
and on vdj
(images thanks to http://www.virtualdj.com/blog/juliocqb/)
that should get you working
now as to a native mapper , it probably will be included in the future but there are some important things they want to add first , so please bare with them on that:)
midi mapping
on the console soft
and on vdj
Posted Tue 07 Aug 07 @ 9:36 pm
thanks.
I got the midi config for VDJ, but I am on a mac, so I don't have the control panel. I must go into audio/MIDI setup.
Posted Wed 08 Aug 07 @ 12:13 am
plus I don't see ASIO in VDJ
Posted Wed 08 Aug 07 @ 12:15 am
how anoying il investigate further :)
Posted Wed 08 Aug 07 @ 1:15 am
thanks
Posted Wed 08 Aug 07 @ 1:28 am
Ryan2288 here some images and a xml that may be helpful too... Enjoy!
http://www.zshare.net/download/30612208b02dae/
Posted Thu 09 Aug 07 @ 8:10 pm
thanks, but is that the correct address? I'm getting server not found.
Posted Thu 09 Aug 07 @ 11:11 pm
