Hi I have a Toshiba Laptop and a Audigy 2 ZS notebook running Virtual Dj 4.3 on Vista. I am currently experience a decrease in sound quality as the night goes on. I play to 2500 people so it does not look(sound) good. Can anyone help!!!
Posted Tue 07 Aug 07 @ 12:26 pm
go to options > performances
and set to fastest
"auto latency"
and untick safe mode
and set to fastest
"auto latency"
Posted Tue 07 Aug 07 @ 2:24 pm
Does this reduce the sound quality! Why is this happening!
Posted Tue 07 Aug 07 @ 5:49 pm
Yes, because for good sound quality you need a good machine ;)
Posted Wed 08 Aug 07 @ 12:18 pm
whats your spec?
Posted Wed 08 Aug 07 @ 2:17 pm
Equium A100-027- Intel® Pentium® Dual-Core Processor T2060 | clock speed : 1.6 GHz , 1,024 (512 + 512) MB | Ram , Intel® | Mobile Intel® 943GML Express chipset graphics card.
Please give me constructive advise and not arrogant replies like the one given by DJ ALF!!!
Posted Wed 08 Aug 07 @ 5:27 pm
the ram is just above the base requirments for vista , you need to dissable all of the vissual effects in vista set it to windows classic , because all of that is using up all the resources.
you should aslo consider getting 2 gb of ram or more
as virtual dj or any music program needs ram to decode the audio
aslo as you have a shared graphics card a whole chunk is aslo being used for your video cards memory
Posted Wed 08 Aug 07 @ 5:47 pm
Okay. Thanks for the info. What settings would you recommend in the performance settings. Has 4.3 become very CPU hungry.
Posted Wed 08 Aug 07 @ 6:12 pm
I don't see anything arrogant in my reply, you asked and I answered to your question.
A little respect if you can please ;)
With your machine you can go on max quality for sure, you should consider 2Gb of ram as Simon suggested. Just a little tweaking you should apply, you have the tutorial in SkyFxl's blog:
http://www.virtualdj.com/blog/skyfxl/
Regards
Regards
Posted Wed 08 Aug 07 @ 6:34 pm
I have respect mate but when someones reply is saying the obvious and nothing constructive its not a great help. But I am sotrry if I insulted you mate. Thanks for the input. I just ordered 2gig of ram.
Posted Wed 08 Aug 07 @ 6:37 pm
In Skys blog it says there is a problem with the Audigy 2 ZS drivers. Would this still be the case even though I downloaded the latest drivers of the Creative website
Posted Wed 08 Aug 07 @ 6:55 pm
ah i forgot about those
http://kxproject.lugosoft.com/down.php
try one of the drivers here
it should have been fixed but , its worth a try :)
Posted Wed 08 Aug 07 @ 7:48 pm
Do I uninstall the Creative drivers!!!
Posted Thu 09 Aug 07 @ 5:19 pm
Yes, remove Creative drivers and install KX Project.
Posted Thu 09 Aug 07 @ 5:57 pm
Thanks Lads for all the help. Sorry Alf for the fall out!
Posted Thu 09 Aug 07 @ 6:02 pm
might be worth sending their support an email to ask when a better driver is being made
Posted Thu 09 Aug 07 @ 6:12 pm
@Deadlyd
No harm done ;) Hope it all goes well.
Posted Thu 09 Aug 07 @ 8:40 pm
Thanks Alf! I was on the creative website and apparantly they are having serious problems with the drivers for my card. The KX project drivers I tried to install not sure how to!! Might buy a new card for my notebook any Ideas for a good Vista compatible card might have to buy 4 for all the dJs!!
Posted Fri 10 Aug 07 @ 5:41 pm
maya 44 usb , or u46djmk2
or perhaps numark virtual vinyl
the dj console mk2 will aslo work if you need a controler while your at it :)
Posted Fri 10 Aug 07 @ 7:30 pm
Have a U46DJ but couldnt install it right. Plus its not 24bit sound.
Posted Fri 10 Aug 07 @ 7:47 pm
