Hello anyone,
my trial of VDJ has just run out and I need to buy VDJ Home edition. I don't seem to be able to find any links on the website, where can I buy it?
benware
benware
Posted Sun 05 Aug 07 @ 1:23 pm
You'd be better MK2 controller and getting V3.4 with it then you have a hardware solution
Posted Sun 05 Aug 07 @ 2:01 pm
You have two options I know of to get the home edition, buy the mk2 or ejays dj mixstation 3. However, I think both only entitle you to 3.4 which is obviously not as good as 4.3 Pro;^]
Posted Sun 05 Aug 07 @ 3:06 pm
if you can speak french there is the newer 2006 home edition :)
http://www.amazon.fr/Virtual-DJ-Home-Edition-2006/dp/B000BR4GPC
Posted Sun 05 Aug 07 @ 3:15 pm
I would suggest get PRO for investment:) if u have some cash to spare.. cos the adventure never ends:))
Posted Sun 05 Aug 07 @ 3:26 pm
Or you can buy Numark Total Control which comes with Numark Cue LE which is 4.1.
Virtual DJ Pro is still the best solution ;)
Posted Sun 05 Aug 07 @ 4:50 pm
I bought the 2006 edition , it works fine for me, I ll probably go pro later or something
Posted Sun 05 Aug 07 @ 6:32 pm
