Hi.
Is it possible to make it so VDJ can run in fullscreen mode but on a second external monitor, rather than the main monitor?
Many thanks,
Tom.
Many thanks,
Tom.
Posted Thu 02 Aug 07 @ 3:10 pm
yes the full version does this quite well.
Posted Thu 02 Aug 07 @ 3:33 pm
You should be able to do so the same way you can fullscreen any program on an external monitor. For best results however, use a VirtualDJ skin which is the same resolution as your external monitor, e.g. 1440x900.
Posted Thu 02 Aug 07 @ 3:46 pm
Ok, thanks for the replies!
Posted Thu 02 Aug 07 @ 3:58 pm
