I had bought Behringer BCD-2000, and i thought "What about Virtual DJ???". Then i downloaded the trial for VDJ, and tried to play it with my BCD 2000. But it stops after well, about 1 and a half minute...
Is there a fix for it or is it just the way it is?? Because it's a little annoying to find out that the thing you bought is able to use with VDJ, but at some point they haven't made a configuration ?? Whats wrong??
Plzz correct me if I'm wrong or any thing but its annoying !
Posted Thu 02 Aug 07 @ 10:07 am
check if its conflicting with any other devices
in performances set latency to auto untick safemode
aslo ensure it is set to BCDJ mode in the asio control pannel
Posted Thu 02 Aug 07 @ 12:41 pm
Well thx for the massesaging, but do know how to check if its conflicting with other devices??
Because i dont have clue...
Posted Fri 03 Aug 07 @ 10:09 am
Ohh u just make a link :P thx
Posted Fri 03 Aug 07 @ 10:10 am
BCD2000 drivers are UNSTABLE with ANY audio software... but it's still a good MIDI controller if used with another soundcard!!!
Posted Fri 03 Aug 07 @ 12:32 pm
