I have been using VDJ for Karaoke. Once in a while I get a request to raise or lower the key. Anyone know how to do this. I don't want the spped of the song to change, just the key
Posted Wed 01 Aug 07 @ 4:58 pm
I have a keyboard shortcut to raise or lower the key for each deck, and a reset button in case you forget what the heck you did to it. I think there is also a key changer effect for download here.
Posted Wed 01 Aug 07 @ 5:00 pm
Its built into VDJ , you can change the key by using a keyboard shorcut mapped to a key, or midi controller.
Or use the key changer plugin
Posted Wed 01 Aug 07 @ 5:22 pm
