I'm having a strange problem with virtual dj for mac. My songs (mp3 files) and videos (mpeg files) are not appearing in the database and not loading onto the virtual deck. Anybody know what can cause this suddenly to happen?
Posted Tue 31 Jul 07 @ 10:26 pm
No I don't unfortunately.
Hopefully skyfxl or one of the beta testers can be of more assistance with this matter.
I just replied to bump your thread back up since you had received no responses.
- VT ConQuest
(Visual Turntablist)
- VT ConQuest
Posted Sat 04 Aug 07 @ 9:37 pm
sounds like the config file may be currupt or the database
first delete the file
com.atomixproductions.virtualdj.plist
then reinstall it should be ok
if not check your database
go to documents > virtual dj
and open up the file virtualdjdatabase(users).XML
in text edit.
and look near the end
ensure all the song tags are closed
they should look like this
<Song FileName="10 The Ultimate [Original Version].mp3" File Size="11993410" Tag Date="701160438">
<Display Author="KrisSy; Trixta" Title="The Ultimate [Original Version]" Tag Read="1" />
<Infos SongLength="16540416" />
<BPM Bpm="17640" Phase="2352" />
<FAME Is Scanned="1" Volume="8324" />
<Atomix Mix Type="3" Tempostat="1131312" Tempo End="15807792" Cut Start="1131616" CutEnd="16336704" Fade Start="1004544" FadeEnd="16356864" />
</Song>
Notice </song> at the end it is like that some songs near the end dont have this and have corrupted the sheet below them add this tag if it is missing
hope that helps :)
in text edit.
</Song>
hope that helps :)
Posted Sun 05 Aug 07 @ 12:28 am
I'm trying to unisnstall in order to re-install because I can't seem to understand how to update my playlists from Itunes (it only did it the first time). I can't!!! Every time my old playlist is there and I can't do anything about it.. What to do? How do you brows / import from Itunes?
Posted Tue 07 Aug 07 @ 9:38 pm
please add your serial..
Posted Tue 07 Aug 07 @ 10:56 pm
