I just downloaded the trail version. when its down i click on the virtual dj icon. it asks what skin i want to use, then it says its checking for updates. After that nothing shows up. What am I doing wrong?
Posted Mon 30 Jul 07 @ 3:12 am
Can you not cancel that?
You can then set the config to "Not check for updates"
Posted Mon 30 Jul 07 @ 1:37 pm
Do you use any unofficial version b4 this?
try reinstalled the trial again..
Posted Mon 30 Jul 07 @ 7:19 pm
is the config in the software?, because i cant get into it.
Posted Mon 30 Jul 07 @ 8:40 pm
I thought it had a cancel button. Then the software opens
Posted Mon 30 Jul 07 @ 11:56 pm
