Sorry About That
Posted Fri 03 Aug 07 @ 8:33 am
any luck with disabling some background services?
I've got a vista laptop (it's only got a 1.86 GHz Pentium M in), and I've managed to get videos and everything working pretty well (no pops or cracles in the music) just by disabling everything that's not needed by virtual dj.
Posted Fri 03 Aug 07 @ 3:34 pm
Last night I ran test of what may be causing the pops, crackles. If I used the MK2 I get the pops and cracks. I then put VDJ on auto 0db. The sounds is better and it change the result a little bit. I ran vdj without MK2 and did everything as usual and had no pops.
That's with video's
Audio wise - I sometime get the pops if I play a deep base song. So I usually turn down the gain.
Tonight before work, I'm going to try turning the computer volume down with 0db on VDJ. If this doesn't work then I may have to check all IRQs.
Yes, Caliente - I tried you method as well and it did not work for me. However, I will keep your method in mind and it to the final testing of all methods together
That's with video's
Posted Fri 03 Aug 07 @ 5:37 pm
Hey Socross, wanted you to check this thread:
http://www.virtualdj.com/forums/75321/General_Discussion/I_need_your_help_______(Laptops).html
I'm not sure if it will help or not, but give it a read.
Posted Thu 23 Aug 07 @ 7:42 am
