Has anyone tried Virtual Dj + Behringer BCD3000 B-Control Deejay USB-mikser?
Is it any good?
What is best
* Behringer BCD3000 B-Control Deejay USB-mikser
* Hercules MK2
* Numark Total Control
* Other??
Thanks for help!
Is it any good?
What is best
* Hercules MK2
* Other??
Thanks for help!
Posted Wed 25 Jul 07 @ 7:46 pm
Hercules MK2 works better with VDJ (long history of native support in VDJ).
Has soundcard included.
The BCD3000 is pretty new, and no good mapper yet, but people are working on it.
The earlier version, BCD2000 had very bad user feedbacks and lots of problems.
But hopefully the BCD3000 is better. Looks more well built too, than Hercules MK2
The Numark Total Control has native support in VDJ, and works great.
But has no soundcard included
Others:
- Vestax VCI-100 (touch sensitive jogweels, WELL made, etc, no soundcard)
- Allan&Heath mixers (VERY expensive)
- Ecler Nuo4 (not too expensive, and is a REAL hardware mixer with midi control, no soundcards)
And to list other midi mixers that are REAL hardware mixers at the same time (no soundcard included
- Korg Live4
- Pioneer DJM800
etc
Others:
- Korg Live4
- Pioneer DJM800
etc
Posted Wed 25 Jul 07 @ 7:49 pm
Definetely you are right Norway, I haven't had so big problems with hercules mk2, more stable, better sound, 2 line in for tccds, etc :)
Posted Wed 25 Jul 07 @ 7:52 pm
Takk for hjelpen Norway! Da forstår jeg det som at det beste valget er MK2, spesielt siden jeg trenger ekstra lydkort noe som er innebygget i denne. Korrekt?
Finnes det noen flighter laget til MK2? Slik at den kommer høyere opp og i litt vinkel?
Posted Wed 25 Jul 07 @ 8:08 pm
MK2 har et lokk, som du kan bruke under (med feste), sånn at den kommer i vinkel.
Noen flight finnes nok ikke, siden den ikke følger DJ standard, og er ganske liten ;)
Og mk2 har innebygget to ut, to inn lydkort + mic og headset ut.. så du har alt du trenger.
Eneste negative med MK2 er at den er nettopp liten, og litt "plastikk".. Ser litt cheap ut...
(english version since most cant read norwegian ...hehe... : )
Mk2 has a lid , that can be used to elevate the mk2. Giving it a nice angle.
There are no flights made for the mk2, as it dont follow the DJ size in the market, its rather small ;)
The mk2 has built-in dual soundcard (two in/two out) + mic and headset out, so should give you all you need
Only negative with the MK2 is the fact that it is small, and looks a bit "plastic".. a bit cheap
Posted Wed 25 Jul 07 @ 8:16 pm
