All of a sudden all the info on the far left of the forms is gone. (IE: map, status etc)
any ideas of how to get them all back?
Posted Sun 22 Jul 07 @ 6:43 pm
I don't seem to have that problem... Maybe it was a small glitch =/
Posted Sun 22 Jul 07 @ 7:14 pm
Could be, but what and how can I get it back??
Posted Sun 22 Jul 07 @ 7:15 pm
There is no problem with the forum.
Just close your browser and open it again ;-)
Posted Sun 22 Jul 07 @ 7:50 pm
Or use Firefox ;)
Posted Sun 22 Jul 07 @ 9:46 pm
Already closed browser. Also I am using Firefox.
Still remains the same
Posted Mon 23 Jul 07 @ 12:25 am
Hm, strange.
Try to update your Java component here:
http://www.java.com/en/
Posted Mon 23 Jul 07 @ 12:55 am
remember you will never see icons on your own name
just others duno if thats what you mean
Posted Mon 23 Jul 07 @ 1:08 am
Alf
I updated and results the same.
Wanted to PM you about laptop but can not as that function is gone.
Sky:
Not my icons. I am talking about the usual info in the far left column. You know where it shows the stars and the map.
Isn't there a way to change it with the forum??
All else works, just not VDJ foum
Also I have even tried a restrore to earlier date. No Good either.
Sky:
Posted Mon 23 Jul 07 @ 7:23 pm
It's got to be a browser issue on your end. It works fine here.
Is it a perfect cut off - or are you able to see part of the column - and can you post a screen shot to your blog?
Posted Mon 23 Jul 07 @ 7:54 pm
CSTOLL;
can't see any jpgs in blog. Was going to try and post here.
I tried to copy & paste, but that did not work. How can I post jpg here??
Posted Mon 23 Jul 07 @ 8:06 pm
Probably need to use a free pic hosting and then use the IMG BB code:
[ img] URL TO PICTURE [ /img]
Posted Mon 23 Jul 07 @ 8:35 pm
http://img508.imageshack.us/my.php?image=vdjfh4.jpg
Does this work??
Does this work??
Posted Mon 23 Jul 07 @ 8:58 pm
Interesting - is this only with Firefox or does it happen in IE as well? Or any other browser for that matter?
Posted Mon 23 Jul 07 @ 9:04 pm
Guess it worked. ANyway see what I am talking about?
Info on far left gone except for name.
Posted Mon 23 Jul 07 @ 9:05 pm
That is strange..r u using firefox.. maybe try using explorer n c if this occurs too.
Posted Mon 23 Jul 07 @ 9:32 pm
@Bogart
I sent you PM so you can reply my friend ;)
Posted Mon 23 Jul 07 @ 11:49 pm
I have completely removed firefox and re installed it. Still not working. I tried to change the settings in browser and this remains the same. I think last week when this happened I hit something to change the way the forum shows, as it went haywire at that point.
I used SBC Yahoo and I can get on with everything showing correctly.
Posted Tue 24 Jul 07 @ 12:18 am
Is there any chance you reinstall OS? Might solve the problem.
Posted Tue 24 Jul 07 @ 12:58 am
You sure do love reinstalling the operating system hehe. Updating the java component most certainly would not do anything either. The forums only utilise javascript and that's for the navigation menu at the top, everything else is pretty much generated server side and sent as html.
The problem seems to be you are not getting images to load up, the reason for this? You probably blocked all images originating from virtualdj's domain. Firefox does not delete your profile when you uninstall so this explains why reinstalling the application did not change this. Click on Tools -> Options. Under the content tab click on Exceptions for automatic image loading and remove VirtualDJ from your block list.
Posted Tue 24 Jul 07 @ 1:43 am
