Forum: Old versions
Topic: Problem firs time with MBP and VirtualDJ
Hi, this is my first time using VirtualDJ on a new MacBookPro. I have installed the 4.3.r13 Virtual Dj version with my M-audio Quatro USB soundcard. The driver of the soundcard is MAC OS 10.4.5 I have red that this version only works with drivers lower than 10.4.6 update, but when I set up once f this drivers my soundcard isn't recognised by the mac, but when I put the first one or newer it does., but in VirtualDj appear "error with soundcard" The problem now is that I'm going to use it and when I enter in the Configuration menu of VDj I can choose my soundcard, but there only this option: when I put Output: External MIxer, the mac only allows me: 3 options: Mono Separated, 2 Cards, 4.1 Card. But It doesn't appear Vynil Code option and I can't use it. So I need help, please!!!!!!
Thanks, I wait your answers.
Posted Fri 20 Jul 07 @ 12:40 am
spinnaJPRO InfinityMember since 2004
In the moment, u cant use any other soundcard for time coded.. u have to use virtual vinyl card only n pls put in ur serial.
Posted Fri 20 Jul 07 @ 9:08 am
