Ok, When I was installing Virtual Dj, I stopped the installation a quarter of the way in, and now when i insert the Disc, instead of it asking to me install, it asking me to uninstall, and seeing as the installation was stopped before completion, it doesn't have the files to uninstall the program, and when i click uninstall this comes up -
>SetupDLL\SetupDLL.cpp(390)
PAPP:Hercules DJ Control MP3\
PVENDOR:Hercules (http://www.Hercules.com)
PGUID:C94D0C97-8A5D-428A-B40B-98EBBDBBA36B
$11.0.0.28844
@Windows XP Service Pack 2 (2600) IE 7.0.6000.16473
Then it says Error Code= -5001
What can i Do?
Thanks, Jecht
$11.0.0.28844
What can i Do?
Thanks, Jecht
Posted Wed 18 Jul 07 @ 9:24 pm
let it uninstall , then
go into the windows registry
and remove any keys relating to hercules
to do this go to run on your start menu and type Regedit
then use the search tool on this to search for hercules ,
delete the keys that show up
be careful not to change any thing else , or this could affect other programs
if this is confusing to you or doesnt solve it i recommened you contact Hercules support.
http://ts.hercules.com/eng/index.php?pg=contact
once its uninstalled i would recommend you find a newer driver from the herc support website
http://ts.hercules.com/eng/index.php?pg=files_faq
Hope its solved soon
Posted Thu 19 Jul 07 @ 7:17 pm
Download the MSI Cleanup Utility from Microsoft's website. It will fix the broken installation.
Posted Sun 22 Jul 07 @ 6:48 pm
