Hi,
I was reading somewhere(can't remember where) that you can make the Mackie SRM450 become wireless. Anyone else heard anything of this?
Kind Regards,
Pat
Kind Regards,
Pat
Posted Fri 13 Jul 07 @ 1:26 pm
There is a wireless transmitter/receiver set on the market, but I can't remember the name of the company (mad cow). I thought it was Phonic, but I will keep looking.
Posted Fri 13 Jul 07 @ 9:31 pm
Posted Fri 13 Jul 07 @ 9:48 pm
are these for powered amps only?
Posted Thu 19 Jul 07 @ 3:52 am
I'd Say it could work with passif speakers although, its using XLR if I'm not mistaking.
Posted Thu 19 Jul 07 @ 1:58 pm
I's only for powered speakers. If you are using passive speakers, you have to amplify them... so, why should you use wireless ones? ok, they aren't directly connected to the mixer... but you must use mono amps, one for each channel...
Posted Thu 19 Jul 07 @ 2:34 pm
