Ever since I installed the mapper, I have a 1/2 second delay when I cue up a song and hit play. This happens on both decks. I don't see a way to correct this. Any suggestions? Before installing the dac-2 mapper I had no cueing problems. The only problem I had was that when the decks were'nt playing and I went to load a song onto the decks, they would over write a song that was already loaded, even though I used the load button on the opposite deck. Someone suggested Cstoll's mapper to solve the problem and it did. However, the delay is really ruining my mixes. Do I need to uninstall the mapper, or is there a way to get rid of the delay?
Posted Thu 12 Jul 07 @ 5:57 am
I would first try uninstallin the mapper just to double check if tbat is it then reinstall it. Computers are goofy so it could be anything ya know. Cheers Brian.
Posted Thu 12 Jul 07 @ 6:39 am
