Bit confused here.
I have the NTC.
I've seem many refernces to the NTC having Touch Sensitive Jog Dials.
Just want to clarify things here, Touch Sensitive as i understand it means that the Jog Dials sense when pressure is being applied to them so that when you keep pressure on them the music doesn't play, you're holding the track in that place (just like Vinyl). Well my NTC certainly doesnt do that.
Unless when they say 'Touch sensitive' that they mean the dials react to your touch in terms of rotating, which ..erm.. is a bit stupid really, ofcourse they do, otherwise there would be no point in having them!
Refernces to sites stating they are touch sensitive.
http://www.htfr.com/more-info/MR222706
http://www.electromarket.co.uk/pp/DJ_Karaoke_Equipment/DJ_Software_USB_Control/PRE_ORDER_NOW_OUT_SOON_-_Numark_Total_Control_DJ_Software_Controller_Virtual_DJ_PC.html
http://www.philmug.ph/forum/showthread.php?t=22481
I have the NTC.
Posted Wed 11 Jul 07 @ 3:41 pm
Correct. The jog dials are NOT touch sensitive.
Posted Wed 11 Jul 07 @ 3:57 pm
You can set the jogs to scratch and kind of give you that effect. They a very sensitive.
Posted Thu 12 Jul 07 @ 4:45 pm
Yes, but not touch sensitive in the terms of sensing downwards pressure being applied
In other words, you couldnt push a jog dial downwards to pause the track and then simply release it to let the track play again.
I stand to be corrected, but this i what i assumed 'Touch Sensitive' to mean in the context of a DJ Midi Controller
Posted Thu 12 Jul 07 @ 6:13 pm
