Hi guys,
Well I actually just about explained myself in the title.
How would one setup VDJ with external mixer and timecoded Vynls. I just bought the maya 44 sound card and I'm looking at the rest of the hardware setup now. Anything I should know?
Thanks
Thanks
Posted Tue 10 Jul 07 @ 9:41 pm
First, you need the full pro version of VDJ ;)
Look here for a guide:
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__).html?page=1
Thats for the Hercules console.
If you wanna use your maya card, the guide above should still be a good start
Posted Tue 10 Jul 07 @ 10:57 pm
Yes definitely need the pro version as i koe that timecoded in the DJC edition permits only 5 mins of usage:)
And u can upgrade with a discount.
http://www.virtualdj.com/purchase/discount.html
Cheers
Cheers
Posted Tue 10 Jul 07 @ 11:05 pm
