ok my problem is connecting my mk2 to the pc. I have the white and red wire going into output 1/2 on the console but where do I stick the other end. Some one told me to stick it into the line in, hmm tryied that and still nuthing. I have a sound blaster x-f1 sound card and a sound blaster x-fi i/o console. Now do I plug it into the back of the pc or the console cause I was looking at the manual that came with my sound card and it has a pic of deck going to the console but I am not sure if this is right
BIG THANKS
BIG THANKS
Posted Mon 09 Jul 07 @ 5:02 pm
The other end goes into your computer / soundblaster soundcard line-in.
Posted Mon 09 Jul 07 @ 5:08 pm
I have mine set up as the small 3.5mm jack going into output 1/2
And then the red and white jacks at the other end going into my amp of my home sound system.
I found the music sounds alot better coming out of proper speakers.
Posted Mon 09 Jul 07 @ 6:26 pm
Ok I did that and still nuthin :(
Posted Mon 09 Jul 07 @ 11:01 pm
heya to get a basic connection to the amp
to get the 3.5 mm jacks to work , you need to change the sliders on the back of the mk2 from phono to line
conect 1/2 3.5 out to the amp
or you can use dual phono cables
and connect phono outs 1/2 to the amp
Posted Tue 10 Jul 07 @ 2:36 am
yeh but I don't want mint to an amp I want mine to go into my pc so i can dj on the radio
Posted Tue 10 Jul 07 @ 5:11 pm
heya,., hi there .. do connect it to the any of the available line-in input at the i/o hub.. n select it in ur surround mixer control panel (creative), example line 1(if u slot in line 1), line 2 (if u slot in line 2) etc and so on. Or u could just select "what u hear" and hear everything wat u play on ur com..maybe rite now u are selecting wave as ur main output, . N there u have it:) hopes that helps
Posted Tue 10 Jul 07 @ 8:34 pm
thanks that helped alot just one question i clicked on speaker icon then went into options then recording and nuthing was there ????
Posted Wed 11 Jul 07 @ 5:27 pm
so basicaly you want to use two cards ?
to record the output of the console
to use with a different radio program sorry im confused
in that case just take a 3.5 mm jack out of the output on the mk2 and stick it in the line in on the other card
Posted Wed 11 Jul 07 @ 6:13 pm
Hi jag , could u tell me more specific:) Speaker icon at where? control panel or VDJ etc?? :)) R u recording from VDJ itself or other software? cos the setting could be different. example maybe urs in line 1, but u try to record at the other software but recording in line 2, hence u cant hear anything..But if u directly record in VDJ , it should be there only question whether u record in wave or mp3 n where u save the file at...:)
Cheers
Posted Wed 11 Jul 07 @ 6:49 pm
I hope this help it is a video I made
http://www.youtube.com/watch?v=svhuVOFZB34
Posted Thu 12 Jul 07 @ 2:44 pm
So wat is ur playback soundcard u use at camfrog? U wanna use with camfrog is it? choose the card example mk2 n try it.:) Do it need to be recorded? (this recording part i have to check when i back from werk in 4 hrs time.:)))
Posted Thu 12 Jul 07 @ 3:00 pm
Jag4life: You are using just the MKII and not an external mixer, correct? I think what you are trying to do is have the output from the MKII be fed into a second sound card so you can broadcast, right? If this is true then when you go to 'speaker > options > properties' tick 'recording', select your second sound card for recording instead of the MKII like you did in the video. That should bring up some options in the empty window. You should be able to use both the 1/2 RCAs and the 1/2 mini jack outputs at the same time, one for your speakers and the other into your sound card. Hope this helps, or at least doesn't make it any more confusing : )
Posted Thu 12 Jul 07 @ 4:53 pm
ok thanks that helped alot got it working only thing is it is coming onto the mic icon and not the speaker one. Also I got one of my friends to come into the room and tell me how it sounds and it said it was very loud but after a while I fixed it
Posted Thu 12 Jul 07 @ 5:54 pm
Yes that is rite:)
Posted Thu 12 Jul 07 @ 6:06 pm
It all works now? : )
Posted Thu 12 Jul 07 @ 7:11 pm
yes it is all working fine now thanks.
Posted Thu 12 Jul 07 @ 8:32 pm
Great, njoy jag:)
Posted Thu 12 Jul 07 @ 8:42 pm
ok recorded a mix and it all sound distorted alot like it is too loud any idea why
Posted Thu 12 Jul 07 @ 9:00 pm
Lower down the Output volume at the control panel of the Mk2 at the Mk2 control panel and also at the creative surrond mixer control, lower down the input volume from (watever line in # u use) from ur creative card. "Too" loud distort the music. :)
Posted Thu 12 Jul 07 @ 9:22 pm
