Forum: Old versions
Topic: HELP!
hey guys... i'm new to this community... i have a question that pertains to quality, i guess u can say... i notice that after altering the master tempo, and then resetting the tempo, there's still some "skipping" as if time stretching still in effect... i mean, technically there shouldn't be any "sound cracks" because the pitch is reset to 0%... not sure why this is happening
also, im new with this program... how it this program compared to other DJing software?... is it up to par with Serato as far as the time-stretching capabilities go?.... just thought i'd throw that out...
thanks for the help
-mark
Posted Sun 08 Jul 07 @ 9:55 pm
To have good master tempo or time stretch quality, you need powerful machine as it takes a lot of CPU power. You can set this in settings>performances and put the slider all the way to the right (best quality) and try master tempo then.
