Forum: Old versions
Topic: Setup help PLEASE!
Hey guys!
I'm pretty new with the digital setup and i need your help!
I want to get a digital set up but i DO NOT KNOW WHAT TO GET! If you can tell me what turn tables,mixer,soundcard to get for my setup to work with V-DJ on my laptop would be great!
thanks!
Posted Sun 08 Jul 07 @ 2:00 pm
what type of dj are you
mobile , club , turntablist?
Club, any link or help on the right setup would be good. Is the Senato any god?
do you need stratch?
could you tell me abit about what you hope to achive and i will recommend somthing for your needs
we dont support sterato here , its a different product.
No, no scratching just mixing and playing. I just need to know a simple setup and simples gears that is available world wide (I live in New Zealand)
Price is not a prob and would like to keep the budget low
so any help would be great.
maybe u could get the herc MK2 for a start:))
If you're a club DJ, you're used to Technics 1210 Mk2? Or maybe the Pioneer CDJ-1000 Mk3? Would you like to extend your ability using these club formats, e.g. by using Timecoded Vinyl/CD. Or would you prefer to escape what you know and use external hardware controllers.
the mk2 dj console is a good bet to start , it is a good controler and soundcard and supports the timecoded vinyl system mentioned above
http://www.virtualdj.com/products/timecode/
you aslo get virtual dj console edition to get you started :)
