Torched my laptop with a spilled beer one night and had to upgrade to Vista and new cpu....VDJ works, however for some reason the new drivers won't install and the Hercules folder is empty under program files. Have installed under Admin, installed/unistalled a few times, got rid of USB devices connected, but my Toshiba Tecra won't let this happen for some reason.
Anyone have this issue? If so, would appreciate any insights.
Cheers,
k
Cheers,
k
Posted Mon 02 Jul 07 @ 5:24 pm
Did you delete the HERC from hardware profiles.
I would suggest you rolling back (System Restore) to before your 1st attempt at installing the soft/hardware.
Also with VISTA when installing the HERC and Vista's "Install Device" shows just ignore or cancel it and let the HERC installer do what is required.
Posted Tue 03 Jul 07 @ 3:32 pm
you might have acidentaly bashed the firmware
http://www.virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
Posted Tue 03 Jul 07 @ 3:44 pm
i like the george bush pic is the icon for "simple" .....lol (asio4all setup ) .......ver funny
if you don't get it follow sky' s link.....
Posted Wed 04 Jul 07 @ 1:25 pm
so far my HP laptop has withstood the ravages of all kindsa Chinese food .......see another reason to like it , cheap , good and won't hurt yer laptop .....'course you will be hungry again in a half hour ......and so will the laptop
Posted Wed 04 Jul 07 @ 1:29 pm
