Forum: Old versions
Topic: koraoke Problem
I am A Cd+g disk for karaoke i want my VDJ to play it what should i do???
Posted Sun 01 Jul 07 @ 12:38 am
You need to have a cd rom drive that reads cdg disks. These can be expensive but should give you the results you want.
Good luck...and keep spinnin'...(",)
P
SFCMARIOLUNA
I do a lot of Karaoke with my VDJ, but when it comes to playing CD+G's, I use a DVD/CDG+G/MP3 player. You can buy one for about what you might put into a good CD ROM drive. And you'll have a back-up, in case your comp or VDJ crashes if you don't mind having your discs handy.
Your going to need to rip your disks into mp3+g format,I don't think VDJ will read a cdg disk even will a cdg drive. P@40
