Topic: alphabetical order ???
when I press one folder the songs aren't in alphabetical order ....... why Not ??????
I don't want to use the mouse everytime !!!
Posted Sat 02 Oct 04 @ 3:56 pm
The songs that were played last are shown at the top. I think there is a reg hack to change this.... Let me see what I can come up with.
thanks Homeboy, I'd be instersted too, but by ascending bpm, not by alphabetical order.
a search on "sort" + "registry" in the General, Technical Support, Bug Report folder didn't yield any results.
I don't see a key that seems to let me parameter that under HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ\ (except maybe AutoSort?), and I won't mess in VDJ's registry without being told to do so :)
This issue is one of the only things that forces me back from the XP10s to the mouse everyonce in a while.
Nicolas
hi
"This issue is one of the only things that forces me back from the XP10s to the mouse everyonce in a while"
same here, so it would be really great to have this
ivar
Your initial guess was right, just change the value of "AutoSort" in the registry to the column number you want to sort against.
thanks dev
yes, many thanks, worked like a charm.
For those who want the default sort to be bpm-based (4th column), the value to enter is "3" (the first column's value is 0).
Nicolas
GREAT thanx a lot
Hey i was wondeirng, see th columns with title artist bpm so on, why dont you press that? tell me what happens, are you worries over?
What is the point of opening a 2 years old problem thread, which was obviously solved ??
Hey duude then why did yu reply if its a two year old thread?
The question is, why did you reply.
