Forum: Old versions
Topic: hi, i need help with setup
hi, i'm looking into getting the virtual dj and i just have a couple of questions.
is there anyway to connect the program so that i can control the program through my numark cd players. i have these:
<img src="http://www.stevesmusiccenter.com/NumarkCDN25GBig.jpg">
what will i need for it to work?
i was thinking
laptop w/ virtual dj
the hercules mk2
a dj mixer
and my cd players
is there an easier way for all this to hook up? if my questions are unclear please tell me.
Posted Wed 27 Jun 07 @ 9:03 pm
Modded: Skyfxl
Posted Wed 27 Jun 07 @ 9:04 pm
sbangsPRO InfinityMember since 2004
you can use this for basic control with timecoded cds
start and stop and pitch but no scratching as the cnd doesnt support this
connect the cd players to the remote
and then cd player 1 into 1/2 on mk2 , 2 to 3/4 inputs
each line represents a dual phono cable
burn two timecoded cds
http://www.virtualdj.com/products/timecode/VDJTimeCode.mp3
as audio cds and then follow this
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
be aware in home edition you are limited to only 5 minutes use with timecoding for longer use it is nessary to
upgrade at a discount
please add your console serial here or pro serial
http://www.virtualdj.com/fusers/modifuser.html
to ensure you can get all the files you need
Posted Thu 28 Jun 07 @ 1:58 am
do i need a sound card to connect the console to the computer?
if so, would a maya 44 external sound card be ok?
Posted Thu 28 Jun 07 @ 2:59 am
