Just getting into this whole Virtual Dj thing but im not very computer skilled so not sure if i have the right soundcard? I have checked out the system details on the pc and it says the soundcard is a SOUNDBLASTER PCI. will this allow me to my next track selection while there is a track playing? Im not sure how to tell if it is 4.1 or not!
Please help.
Cheers.
Craig.
Please help.
Cheers.
Craig.
Posted Sun 24 Jun 07 @ 7:21 pm
If you have some property software that came with the card, in there you should have option to choose between 2 or 4 channels output. Also check in Control Panel>Sounds that 4 channels are enabled.
Posted Mon 25 Jun 07 @ 4:21 pm
