hi, i'n new to virtual dj and can't get sonique to display when i select a tune, any ideas what i'm doing wrong?
Posted Wed 20 Jun 07 @ 12:59 am
If you haven't done it already you need to download some Sonique-content and load it to make it work.
Since you are a registered user you will find this under the "Download" menu of this web-page.
Posted Wed 20 Jun 07 @ 2:26 am
Go to config>video>check the box for "use this plugin for audio-only files". In the pull down menu, you should see Sonique.
Posted Wed 20 Jun 07 @ 8:06 am
