Forum: Old versions
Topic: SDK question: execute pitch reset possible?
Hi there!
I just wanted to ask if it's possible to execute pitch reset from an effect plugin?
Why? I've got the DJ Console and want to reset the pitch (slow way) using a button from the console. Using an effect seems the most elegant way to do this.
Greetings,
SvOlli
Posted Wed 29 Sep 04 @ 5:44 pm
A plugin could do it but you don't really need a plugin to do this.
You can easily create a shortcut. This way a slot effect is not lost for it.
With the shortcut you can choose which desk you want to assign with you your key (or the default one).
Clax
