Hi recently bought DJ control MP3 and it came complete with virtual Dj v3.1
But when I upgraded to Virtual DJ v3.4 something happened.
In Virtual DJ v3.1 the auto beat buttons on the DJ Control MP3 deck, when I pressed either of them it is assigned to the "sync " command in Virtual DJ. (Which I like)
But now when I upgraded to v3.4 the Auto Beat buttons on the DJ Control MP3 deck is now assigned to "autobeat" buttons in Virtual DJ. Is there any way I can re-assign back to the "Sync"? Because I really hate that autobeat command in virtual DJ?
Thanks
Al
Thanks
Al
Posted Fri 08 Jun 07 @ 7:19 pm
There is a MAPPER you can download
The other option is to just use it as a MIDI and Map each key yourself.
again may not be available for home version. I upgraded to pro after I found out how
many cool tricks are not available in home.
Thanks,
Thanks,
Posted Fri 08 Jun 07 @ 7:39 pm
He can't because he is the Home version user and you need Pro license to download Mapper.
Posted Fri 08 Jun 07 @ 9:39 pm
That sucks that I cant download this mapper to fix a problem caused my a virtual dj upgrade. Is there any way I can buy this mapper instead of upgrading to pro?
Thanks
Thanks
Posted Mon 11 Jun 07 @ 11:47 pm
midi mapping and mapper support is only included in v4 pro
Posted Tue 12 Jun 07 @ 11:35 am
