Forum: Old versions
Topic: Vista + Hercules MK2 + virtual DJ sound problem solution
Just found the solution for headphones and sound outputs trouble with the following setup:
you just need to go to the compatibility mode (right click on virtual dj shortcut and compatibilty tab) and switch to windows xp and problem solved!
hope it will help
Posted Fri 08 Jun 07 @ 5:28 pm
