Forum: Old versions
Topic: Max Load
Hi i have downloaded the pc version demo and i am using in trial version until i get to buy it. But i have got a problem.
I usually use a technique with long samples to mix Progressive/House up to 2hrs of load on every deck.
I am asking why the Max Load setting is set to always but the sample does not load and i do have a lot of ram.
Can i set it from somewhere else??
Thanks and great Soft!!
Posted Wed 06 Jun 07 @ 10:29 am
how much ram?
1GB
Its a Dell Duel Core T1350 @ 1.86GHz, 1.86GHz
1GB Ram
im not convinced that 1 gb is enough
i will investigate.
as the whole files need to be loaded into the ram to play
If they are up to 2 hours than it is certainly not enough, try to add another Gb (2Gb total).
even if the whole file is 200mb?? ... well ok thanks for the help!
remember other programs are using the ram too windows on it own might use say 700
or in the case of vista 1 gb!!!
ok thanks for your help!
No problem, glad we could help!
