i have the hercules dj console that came with the virtual dj program now i have to buy the dj console mix2 inorder to use and download new skins for virtual dj.i believe i have the first edtion the installation cd say version 1.3
Posted Tue 05 Jun 07 @ 6:24 pm
you need to buy virtual dj pro
to get full updates
the console comes with home edition.
to get full updates
Posted Tue 05 Jun 07 @ 10:19 pm
You can get some skin's for it but not all of them.
Posted Wed 06 Jun 07 @ 6:14 pm
you must at least be a home user to acess skins.
and then you have acess to home level only
for the full experiance you need pro :)
hope to see you with us soon
Posted Wed 06 Jun 07 @ 6:20 pm
I just purchase the virtual dj and i wanna know how do you send the screen to projector or plasma screen what kind of device that i have buy for that.
thanx=)
thanx=)
Posted Wed 06 Jun 07 @ 8:47 pm
sure il show you
add your serial here :)
http://www.virtualdj.com/fusers/modifuser.html
to show you own it first tho if you would so you can get the latest updates for stability :)
Posted Wed 06 Jun 07 @ 9:01 pm
