I have a problem when i use two icdx's with virtual dj . when i play a video and try to cue up a song on the other deck i get a really nasty popping noise that makes the sound very distorted.
My specs are as follows .
VDJ 4.3 pro
2Numark ICDX's
Vestax VCI 100 midi controller
Athlon 2x duo 3800
ASUS M2N32 sli Deluxe Motherboard
4GB DDR2 400mhz Ram
500GB SATA2 drive
M-Audio Delta 44 audio card with breakout box
Nvidia GForce 6600 GT Oc Video Card.
VDJ 4.3 pro
2Numark ICDX's
Athlon 2x duo 3800
4GB DDR2 400mhz Ram
500GB SATA2 drive
Posted Tue 05 Jun 07 @ 1:46 am
You have a great pc, however I have dual HD to make it load faster.
try to do this, play the video from the internal HD, and load the song from a USB HD, or network.
tha will show if the problem has something to do with the data transfer from your HD.
Posted Thu 14 Jun 07 @ 1:34 pm
