Forum: Old versions
Topic: mk2 and vista HELP HELP
i can't get the mk2 to work with vista. can anybody help? I'M HAVING A PROBLEM HEARING SOUND. HELP ME PLEASE
THE CONSOLE WORKS OK, JUST DON'T GET ANY SOUND!!! PLEASE HELP
Posted Sat 02 Jun 07 @ 5:53 am
uninstall the console
software and vdj
go to comtrol pannel and go to user acounts
add your self to the administrator group
then restart then reinstall
That will solve the direct x sound error also?
yes
I'm already the administrator.....Is there something im missing?
Vista doesnt see it that way, you need to do what Sky said as just because you are the admin when u installed it, doesn't mean you are the admin all the time. I know it's strange.
i go to user groups.....the only option it gives me is for admin, or standard user. i'm already admin. or should i try standard user? but then i wouldn't have admin options?
ok just to confirm your using the 2007 driver package?
yep, now i uninstalled everything. now i can't get virtual dj to install it freezes up! It gets down to 2 seconds to finish installation then freezes...worked fine last night. You mean the driver package for hercules?
yes the latest one from their website
Yep, do u know y virtual dj won't load now? should install virtual dj first? then hercules? does it matter? i'm ready to throw my new laptop out of window!
herc first the software wont load without the console
did that. now virtual dj won't install at all............it freezes..
PROBLEM SOLVED!
Go to control panel then disable everything under sound and video controllers! Then plugin the hercules. worked fine after that! the sound cards were colliding giving me a direct x error!! The internal soundcard wasn't shutting down while plugging in the hercules...so i take it that it was trying to use all 3.
No problems after that! Works awesome!
thanks doug
need help? email me or hit me up via yahoo dougiefreshthedj@yahoo.com
im=dougiefreshthedj for aol and yahoo
I hope this helps some people.
