Forum: VirtualDJ Plugins
Topic: Plugins for Master audio output
djcelPRO InfinityModeratorMember since 2004
These plugins are applied at the end of the chain. That means after the mixer and after the sampler. So the effects are applied on the sampler too (you can test it if you don't load songs on decks and only play a sample)
Posted Fri 01 Jun 07 @ 11:36 am
ciocePRO InfinityMember since 2004
Many thanks DJCel for you new pack of Sound Effects, I will test this weekend ;)
Posted Fri 01 Jun 07 @ 12:41 pm
Nice one!
Posted Fri 01 Jun 07 @ 10:11 pm
it sounds good. I will test quickly ;-)
Posted Fri 01 Jun 07 @ 10:34 pm
