unlike the older versions of vdj... i jus cant select a timecode bypass with numark cue????
Posted Thu 31 May 07 @ 5:34 am
There is none, bacause it didn't work very well.
Posted Thu 31 May 07 @ 3:41 pm
its being looked into
Posted Thu 31 May 07 @ 4:32 pm
as well it should be, totaly bemused me when they took it out
Posted Fri 01 Jun 07 @ 1:21 am
I might be missing the point here, but won't turning the timecode button on and off while playing act as a timcode bypass??Or are you talking about something else??
Posted Fri 01 Jun 07 @ 1:47 am
they are talking about a feature that was available in a previous version.
it was possible to use normal vinyl, send it through VDJ and output it on the soundcard.
Posted Fri 01 Jun 07 @ 12:50 pm
