last weekend i was using numark cue on my mac pro. the sound would cut out every so often. mainly when i mixed from one deck to the other.... or when the it was going through a playlist... it would be playing off the left deck... automatically switching to the right deck... sound would cut out... id then have to go to preferences and reselect my sound options before it kicked back in... really frustrating.. tried restarting... tried reinstalling... finally gave up... that was friday.
saturday i didn't experience the problem at all....
Posted Wed 30 May 07 @ 8:58 pm
how odd , what where you doing at the time this started did you alter any config?
Posted Thu 31 May 07 @ 1:09 pm
I may have altered the quality settings... moving from latency to quality.... and switched from mixer to single output.... but nothing out of the ordinary.... the behavior was so irradic....hasn't done it since.... but it's making me scared.
I'll keep an eye on things....
I wish i knew exactly why this issue was caused.
Posted Thu 31 May 07 @ 9:03 pm
if a card recives a latency it doesnt like it will stop
some cards cannot support some latencys
so if you change a setting while mixing this will cause it to stop
strongly suggest notmaking config changes live
Posted Thu 31 May 07 @ 9:25 pm
OK i'll keep the slider on quality from now on... im more concerned with sound and video quality anyway, until i go to the next step and hook up my virtual vinly that is.....
Posted Thu 31 May 07 @ 9:51 pm
well the random sound loss happened again last night.... no explanation... i started the program.. it worked fine... then the sound stopped when i switched a song...
to get it back on... i needed to go to preferences... and reselect, the already selected sound options... (single output, mixer, and soundcard)
frustrating... this program is unusable.....
after a while... a new error.... the program stopped detecting all of the songs on my computer... nothing was showing up... i had to reinstall....
can't tell you how many times ive had to reinstall this program... i want my money back.
Posted Fri 01 Jun 07 @ 4:22 pm
i suggest you make a support ticket
they will be able to help you further
contact
contact
Posted Fri 01 Jun 07 @ 4:30 pm
