Although Cue VDJ sees iTunes playlist, I get an error trying to load a song to a deck unless I load it from the local database window. This is terrible considering I spent weeks of endless days organizing my iTunes library. I was using Torq but I hate the look and price of their controller. Cue is pretty hot if it does all that it's supposed to do. I also would like to know how I could get the full version so I can take advantage of some of the LE limitations.
-R
-R
Posted Tue 29 May 07 @ 8:09 am
is this itunes purchased music because only itunes can play that as its drm protected.
Posted Tue 29 May 07 @ 10:58 am
No. I converted everything in my library 4 months ago - to avoid compatibility issues. The iTunes library is however on an external drive. I don't think that should make a difference. I just thought I should mention it. All my music files are mp3/192kbs. I can access them from the local database but not from the iTunes playlists which do show up in Cue Le's database window. I've also analyzed the entire library but the bpm's don's show up until I load a song. This is also a major drag considering, I thought the bpm's would show up after I analyzed the library which would give me some temporary flexibility to use Cue in a live setting.
-Looking forward to your response.
-R.
-R.
Posted Wed 30 May 07 @ 8:51 pm
please try reinstalling the product.
Posted Wed 30 May 07 @ 10:15 pm
Thanks skyfxl. I did as you suggested and still - I get errors when I try to load songs from my (iTunes) playlists. After A/B'ing your software and Torq I think the actual sound (I'm a recording and production engineer) is superior to Torq. However, if I can't use my iTunes playlist I'm not so sure about the Cue LE version. I spent a great deal organizing those playlists and update it weekly. I've been doing this since November of last year. If I could at least get Cue Le to show the BPM's after I analyzed the entire library that would be a temporary "work around" but that didn't work either??? Is there anything I can do to get this to work? I have 3 days left to return this software/hardware. I don't want to but I will if it won't work.
signed,
Hopeful.
signed,
Hopeful.
Posted Fri 01 Jun 07 @ 8:07 am
hi there
le is a limited edition , but it should still work
im not sure if you can return the software once its been registered on the site
i will see what i can discover
i suggest you aslo make a support ticket
contact
contact
Posted Fri 01 Jun 07 @ 12:32 pm
Thanks Sky. I'll try the ticket.
Posted Fri 01 Jun 07 @ 4:52 pm
