Can anyone tell me what the best setting is for the "Max Load" Option under the Config sttings in Cue?
I have it set for "Always" right now, but I'm not sure if that is a good setting or what the settings actually mean for the Max Load option.
Thanks,
Freakndj
Thanks,
Freakndj
Posted Mon 28 May 07 @ 12:35 am
Personnaly i use 15 min and i advise it for users but always can have advantages for video (if you have at least 2GB of RAM to avoid a possible full RAM)
Posted Mon 28 May 07 @ 10:59 am
Same here, 15 min is the best, but it depends of amount of ram U have. I use audio only and have 1Gb ram.
Posted Mon 28 May 07 @ 11:17 am
Personally I have it set to "Always", but the maximum song length I'll load would be about 10 minutes.
Posted Mon 28 May 07 @ 11:25 am
Ok, thanks.
I have 1 Gig of Ram on my lap top I am using.
I'll set it for 15mn, and try it like that fro awhile.
Right now, I'm just playing mp3s.
Freakndj
Freakndj
Posted Mon 28 May 07 @ 5:05 pm
