ok put it like this im using the maya 44 usb with timcoded vinyls right ok we ni load a song and then i press the tab space it plays by itself and it dosent go with the timecoded vinyl like if it wass jus runnin by itself how do i make this to stop thats the onli problem i have and i have the version 4.3 and it gets me a lil bit mad wen im bout to mix or scratch pliz help so that i can fix my stuff to run flawlessly and im using windows xp and gemini tt-02 and mx o4 yea u get the point well i hope some1 will help later
Posted Sat 26 May 07 @ 6:37 am
Are you a registered user??? I thought the trial was 4.2.
Posted Sat 26 May 07 @ 7:16 am
OK, You really are a dumb ass...
You already told us you were using a cracked version... Why should we even talk to you?
What do you expect? It's designed to not work right if you're not using an authentic license dude! That's your problem, you're using a cracked version. end of story genius!
I mean do you really think we're gonna' keep helping you when you're a software pirate?
Buy the software, and then clean up your language, and maybe we'll be willing to work with you.
the cojones on this kid! I mean geez!
Posted Sat 26 May 07 @ 10:03 am
grab a legit copy of the demo here
www.virtualdj.com/download
and then try to set autolatency on the performance tab
it wont work on a crack
hope to see you wiith us soon.
Posted Sat 26 May 07 @ 11:30 am
wateva dude ,hope u happy.. from a PRO user..
Posted Sat 26 May 07 @ 6:58 pm
djMySTERiO please stop.
that sort of language is not aceptable anywhere ,
you will not be warned again.
Posted Sat 26 May 07 @ 7:03 pm
