im new 2 all this and im thinking of buying a the hecules mk2 with vdj3, i have windows vista, im
i doin the right thing 2 purchase this, as i hear that ther r loads of probs with vista
Posted Fri 25 May 07 @ 2:20 pm
it works perfectly if you follow the install instructions many tend to try to guess and mess it up
Posted Fri 25 May 07 @ 4:11 pm
Not a single problem...
Posted Fri 25 May 07 @ 4:56 pm
there's always problems with the new , it's in the nature of things
if you let that stop you ........
there is a lot of great support here especially for the herc ..........
give yourself 2,3,4 days before your next gig to make all these changes and work with it a little and you'll be fine
chuck8675309
chuck8675309
Posted Fri 25 May 07 @ 11:36 pm
finaly i purchased the hercules mk2 console with virtual dj, would it be possible to upgrade the virtual dj software and still use my console,
Posted Sat 02 Jun 07 @ 9:50 pm
yes upgrade here
discount upgrade
discount upgrade
Posted Sat 02 Jun 07 @ 9:57 pm
I am using Vista and Mk2 and it works a hell of a lot better than XP.
Posted Sat 02 Jun 07 @ 11:49 pm
