Hey guys, im a beginner and im having sample problems. each time I load some of my downloaded loops online, and i want to mix them in, the virtual dj writes "jingle" on top of them in the sample, while i want them to be loops. Is there anyway to fix that?
Posted Fri 25 May 07 @ 11:06 am
hello, i suppose that you have "jingle" bottum pressed, you have to press on "loop" bottum and than your sample will be fixed as loop.
Posted Fri 25 May 07 @ 1:57 pm
no, the problem is that these loops i am using are loaded from the hard disc.
Posted Sat 26 May 07 @ 7:42 pm
