Just raised my stress level to defcon 3 trying to figure out how to set up. I don't have an ASIO soundcard yet, but can still use the TCV’s with the 3 soundcards I have? I have VDJ 4.3, AMD Athlon 64 3700+ 2.20GHz Soundblaster live 5.1, Realtek AC'97 & Creative Soundblaster and am using GEMINI TT02 Turntables and GEMINI PS-04 mixer. I quite don't understand how to configure the ASIO driver to use TCV with the equipment I have. Is there something I need to do to the 3 soundcards or the ASIO config page? I have read through the forums for days and I’m just not understanding how to get it going. Maybe some sort of diagram would help me….ANY help would be gladly appreciated.
Posted Sun 13 May 07 @ 3:27 am
you need to use ASIO4ALL. download that and run it, you should see all 3 cards active (green) If you got that far then the rest is all cables and vdj settings. Make sure you have the turntables plugged into the input of the soundcards and the output into the mixer. As far as i know vdj is only going to use 2 cards at once. What would the 3rd be for recording?
Posted Mon 14 May 07 @ 4:52 pm
I have ASIO4ALL, but not sure how to configure it to use TCV & that third card I added thinking it would make it clearer to me. :-(
Posted Tue 15 May 07 @ 1:33 am
ASIO4ALL is pretty simple, open it and look to see (hopefully) all your soundcards active, I believe it should be green or if they are not it might have an red X. If the card is listed but not green or X then click on the card listed and press enable button. The main point is to see if all your cards are active and enabled. If all the cards are active then you can go ahead and open vdj and configure. If you can post a screen shot of ASIO4ALL so we can see the status. It might help.
Posted Tue 15 May 07 @ 2:13 pm
