Ok I cant figure out how to get my TCV to work. I have my laptop, then I have my M-audio 1814 hookup to my laptop. The 1814 is then hook up to my mixer. Turntables are hooked up to my mixer. What else do I need? It's not working. HELP!!!!!
Posted Fri 11 May 07 @ 6:02 pm
Is there some type of picture that I can follow. I'm not understanding how everything comes together.
Posted Fri 11 May 07 @ 6:16 pm
If you look under help in the menubar there are tutorials by users on the hookup. You're missing hooking up the TT's to the Soundcard input then the soundcard output to the mixer.
Posted Fri 11 May 07 @ 8:08 pm
Posted Sat 12 May 07 @ 5:29 pm
You have to have the turntables hooked up to the sound card for the TCV to work. Basically you hook the turntabled up to the inputs of the 1814 sound card and then assign one turntable to channels 1 and 2 and the other turntable to 3 and 4 for inputs then hook the sound card outputs 1&2 to channel 1 on the mixer and 2&3 to channel 2 on the mixer
then run the tc auto-setup in VDJ
Posted Sun 13 May 07 @ 10:19 am
